Can anyone answer why Studebaker placed lock washers with the upper inner A-frame bracket-to-frame and used flat washers on heh lowers ? And assuming I will re-thread by die....should I use lock tite on the inner bolts w/ flat washers ?
Question (and funny observation)..
Tags: None
Lock Tite wouldn't hurt. I am guessing that they figured that to change the camber it would sometimes need to turn the upper control arm shaft 180 degrees so the lock washers were a "just in case" thing. Other than replacing the bushings the lower arms have no need for removal & even then the bushings can be replaced one at a time without removing them.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
