I need a rear axle shaft oil seal for a '83 Avanti. These cars came with a Dana 44 rear axle with flanged axle shafts. Would any of You out there happen to have a good part number for this shaft seal? The rear brake shoes (11") interchange with the same era Chevy C-10 pickup truck. I wondered if the axle shaft oil seal would also interchange with that truck model? Thanks much, SN-60
Axle shaft oil seal needed!
Tags: None
Ed
IIRC I used the rebuild kit for a 74-80 Scout II when I rebuilt the rear axles on mine.
Take the old seal to the closest 4X4 house and they will match it up but I'll bet if you don't have one to match the Scout II seals will work.
BobLast edited by sweetolbob; 03-29-2013, 02:45 PM.
