View Full Version : Frame/Springs Buick (GM) front spring installation on Sat.
jackb
03-29-2013, 04:07 PM
I'm set to install the later model GM rear springs in the front of my 62' Lark V8 tomorrow. I've always installed NOS Stude springs with the bottom coil ends facing the engine. Same with the GM's ?? Haven't even opened the box yet, but know to expect a conical coil top....
JoeHall
03-29-2013, 04:33 PM
No conical top. Looks the same from either end, except the coils with the rubber protector/sleeves go up.
jackb
03-29-2013, 08:27 PM
ok...just opened the box.....I guess my last question is do I rotate the bottom of the spring so that the end faces in towards the engine....and does anybody know why ?
JoeHall
03-30-2013, 07:38 AM
I have always installed them that way b/c that's how the Shop Manual says to do it, and it is easily accomplished.
Captain Billy
03-30-2013, 05:37 PM
Joe, the protector/sleeves side up into the pocket? I am doing this install as well and just want to double check.
Bill
JoeHall
03-30-2013, 09:17 PM
Bill
By protector/sleeves, I was referring to the the rubber wound around the upper coils. The springs install exactly same way as OEM ones. I'd also install the upper and lower rubber cushions, to avoid squeak. If you don't have them, they're easy to fabricate, i.e. split a piece of rubber hose and slip it over the upper & lower coil, and hold in place with 2 or 3 nylon tie-ties.
