Because the original Stop/Tail/Signal rear sockets are so old and corroded, I am replacing them. The pigtail wires on the new sockets are both black, and the 2-button base can go in the socket 2 different ways, in other words, depending on this and how it is wired, either of the two elements in the bulb could be the tail light element and the other the brake/signal element (in spite of the fact that the fact that the bulb can fit into the socket one way because of the staggered pins on the side. So here is the question: Which element is intended for the tail light function and which element for the brake/signal function, the upper or the lower element?
Wiring for Stop/Tail/Rear Signal sockets--'63 Avanti
Electrical: Wiring for Stop/Tail/Rear Signal sockets--'63 Avanti
Stan Gundry
www.AvantiPublishing.comTags: None
Originally posted by Stan.Gundry View PostBecause the original Stop/Tail/Signal rear sockets are so old and corroded, I am replacing them. The pigtail wires on the new sockets are both black, and the 2-button base can go in the socket 2 different ways, in other words, depending on this and how it is wired, either of the two elements in the bulb could be the tail light element and the other the brake/signal element (in spite of the fact that the fact that the bulb can fit into the socket one way because of the staggered pins on the side. So here is the question: Which element is intended for the tail light function and which element for the brake/signal function, the upper or the lower element?
Bob
What Bob said. Brightest element is brake/turn signal.
When I installed mine I simply twisted the pigtail to the harness and checked the brightness, switched if necessary and spliced with heat shrink connectors.Brad Johnson,
'56 Sky Hawk in process
