What gas/octane do you guys recommend for the 289 4bbl's? Do I need a lead additive?
What Gas?
Has the motor been rebuilt with hardened valve seats etc? Have the heads ever been resurfaced or milled? How much do you drive it? What are you using in it now? There are few, if any, legal "lead additives" available for street driven cars, there's stuff called "lead substitute" which is really just top oil. I use 100LL avgas when I can afford it or 92 octane non-ethyl gas whenever I can find it and premium ethanol-contaminated pump gas when I'm traveling, since that's usually the only stuff I can get. You may get by with regular or middle grade pump gas if you adjust your timing to where it doesn't "ping".
any octane without ethanol would be best! it looks like you have at least one gas station in your area: http://pure-gas.org/index.jsp?stateprov=INKerry. SDC Member #A012596W. ENCSDC member.
Originally posted by Corvanti View Postany octane without ethanol would be best! it looks like you have at least one gas station in your area: http://pure-gas.org/index.jsp?stateprov=IN
The Stude with 8.5 compression isn't really finicky about gas. I ran our E10 regular 87 and 89 octane for fifteen years with zero problems to fuel pump, lines or carburetor. There was some exhaust valve recession over that time. So yes, hardened exhaust seats are a good thing on a rebuild.
jack vinesPackardV8
Originally posted by Washtubman View PostWhat gas/octane do you guys recommend for the 289 4bbl's? Do I need a lead additive?
[If the question is about the car in your picture, then 87-89 octane.]
I would say 87-89 octane for the former and 93 or higher for the later. No lead additive if the engine hasn't been apart for years.Gary L.
Originally posted by Washtubman View PostGuess 87-89 is what it will be. Not sure what Sunoco 260 is.
- Likes 1
My parents used to run Sunoco 260 in our '67 Corvette that had the 427 w/Tripower back when gas was that cheap. At 10.25:1 compression ratio, I dunno if I'd call it a requirement, but more like a really strong recommendation to use that kind of fuel for that car. However, since most of ours run in the 7-9 compression ratio range, regular unleaded 87 should do just fine. Thank goodness too, because even though my R2 Lark has gotten by just fine on 87, short of the very distant infield of the Rt. 66 Speedway, I haven't seen a Sunoco station, or a station selling anything that high around here for years.1964 Studebaker Commander R2 clone
- Likes 1
From their race fuels website here is a link:
Fuel Comparison Chart
Displaying 1-20 of 20 result(s).
Name
Leaded
Color
Octane
Research Octane
Motor Octane
Specific Gravity
Oxygen (weight%)
No Yes Under 95 95 to 105 Over 105 Under 95 95 to 105 Over 105 Under 95 95 to 105 Over 105 None 0 to 3 Over 3
260 GT No Not Dyed 100 105 95 0.767 3.3
260 GT Plus No Light Blue 104 110 98 0.762 4.5
260 GTX No Green 98 103 93 0.762 0.0
CF No Not Dyed 96 102 90 0.757 2.7
E85-R No Pale Green 99 104 94 0.790 29.0
FR No Not Dyed 96 102 90 0.767 3.7
GP2R No Not Dyed 94 99 90 0.728 2.7
GP4R No Not Dyed 94 99 90 0.729 2.7
Green E15 No Green 98 104 93 0.742 5.6
MO2X Unleaded No Not Dyed 97 101 93 0.716 2.7
Optima No Teal 95 98 92 0.723 0.0
RMR No Not Dyed 94 100 89 0.759 2.7
SS 100 No Not Dyed 100 104 96 0.715 3.5
EX02 Yes Light Orange 107 114 100 0.750 10.0
HCR Plus Yes Orange 114 118 110 0.739 0.0
Maximal Yes Red 116 118 114 0.708 0.0
MaxNOS Yes Yellow 116 119 113 0.731 0.0
MO2X Leaded Yes Dark Green 112 116 108 0.720 2.7
Standard Yes Purple 110 114 106 0.729 0.0
Supreme
ww.racegas.com/fuel/compareJohn Clements
Christchurch, New Zealand
Not sure about Anderson, but here in Noblesville on S. 10th street is the Country Co-op, real gas! NO ethanol. If you come down, stop over.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
