Parts 11
Washtubman, first one is a armrest, which I would be interested in buying if you want to sell. Let me know. I'll send you a PM also.
Originally posted by Washtubman View PostSorry about the double post; but I don't know how to delete one of them!
BobLast edited by sweetolbob; 03-22-2013, 04:10 PM.
First pic is a truck armrest, which I would be interested in if you want to sell . Second looks like the part contacts for a wiper motor, fourth looks like a Lark neutral safety switch. Fifth is a speedometer pinion and gear....they should have a Stewart Warner part number that you can cross reference in the parts manual.
This is Odd just Links appear. Pics do not appear on the Post without opening the links, this has NEVER happened before. This took me a while!
369 A "C" Cab Truck '49 to '64 Arm Rest Kit
370 An unknown part of an Electrical Device (switch) may not be Studebaker, if it has a Coil on the back it may be a rheostat. Probably broken and junk.
371 A 1956 Hawk Heater Fan Switch.
372 A Back up Light Switch that IF it has 4 rather than 2 Contacts on the back would be for Automatic Trans. Cars with a Neutral Switch, otherwise it's for Manual Trans. 1961 to 1966 Larks and Lark Types.
373 Is a Speedometer driven gear -Pinion and the large gear is the Drive Gear inside the Trans. on the output Shaft.
If you read the tiny print on the Pinion it will say: SWxxxx the Stewart Warner Part Number followed by the Studebaker Part Number for the correct Rear axle ratio etc.
374 If this part is only about 4 1/2 to 5 inches long, it is a Ash Tray Guard for late 1964 to 1966 Lark Types that should fit all '63-'66 Larks & Lark Type Models.
375 and 376 are a Door Latch that if good, MAY be the correct one for your Car.
Next time try using the 3rd. ICON to the right of the Smiley Face Icon.
Whew! that's 21 minutes I will never get back!Last edited by StudeRich; 03-22-2013, 07:05 PM.StudeRich
Originally posted by Washtubman View PostWell, I keep going thru the "stuff" that came with my car and keep finding "stuff" I have no idea what it might fit. On my first post you guys gave me great help and hoping I can get some help identifying these parts and what years/models they may fit. Thanks.
[ATTACH=CONFIG]22369[/ATTACH][ATTACH=CONFIG]22370[/ATTACH][ATTACH=CONFIG]22371[/ATTACH][ATTACH=CONFIG]22372[/ATTACH][ATTACH=CONFIG]22373[/ATTACH][ATTACH=CONFIG]22374[/ATTACH][ATTACH=CONFIG]22375[/ATTACH][ATTACH=CONFIG]22376[/ATTACH]
3464 jpeg, looks like 50 Commander radio delete blank.....or if it's smaller, the ash tray trim for the same model.Bez Auto Alchemy
For owning a '57 Silver Hawk? this former owner sure did have an array of various year stuff. I wonder if he was a real Stude. collector?StudeRich
