Well, a while back I made a trade for a 61 Hawk. It originally had a 3 speed with OD trans, which at some point had been replaced with a straight 3 speed. The 3 speed worked, but leaked oil.
I recently replaced the trans with a used T86 with OD. I did a lot of cursing and swearing trying to get the trans installed by myself, but finally managed. Seems like the only help I get is from my closest friend Murphy, you know... the founder of Murphy's Law? Anyone that is not familiar with Murphy's Law, just google it.
Anyway, I was quite happy to have the overdrive back in it, and figured I might have to sort out some electrical issues to make it work, but not a big deal.
So I try to back the car off the ramps hat I had under the front tires... and it won't move in reverse. Forward is no problem. I had read a little about the BW OD operation, and recalled that in certain instances they freewheel, so I thought it was something I wasn't doing properly. If I am understanding correctly, the transmission has an internal linkage that disables the OD in reverse, otherwise, it wouldn't move in reverse.
I pull out the OD handle to disengage it, put it in reverse, and... still no reverse.
So today, I put it back up on stands, and verify that the OD was engaged all the way, and try it again. it wouldn't even turn the wheels off the ground. In gear, I could turn the driveshaft one way, but not the other, indicating that the OD is engaged. I move the lever all the way to disengage the OD, and again, no reverse, only some occasional noise. In gear, I could not turn the driveshaft either direction, indicating the OD is disengaged. Then I ran out of time as I had to take my boy to baseball practice.
Tomorrow I am going to remove the R-1 shift linkage to verify that it is engaging 100% into reverse, but I am already 99.9% sure it is. Looks like I will be reinstalling the 3 speed for the time being, and will tear the OD trans apart when time allows, probably over next winter. Just when I think I am done dumping money into this pit... I mean project, I find something more to spend it on. And to top it off, it has been snowing all week. In case you were wondering, I dislike snow and cold.
On a positive note, I woke up alive this morning, so all in all, it was a pretty good day.
