View Full Version : Needing 6 volt battery.
Jimmie
03-19-2013, 12:40 AM
My 6 volt battery has died over the winter. What is the most CCA I should expect to find and where should I look for one. What about a tractor battery? Thank you to anyone who can help me.
rockne10
03-19-2013, 01:30 AM
Your six-volt battery is classified Group One. I get them from Interstate. Any supplier will know what a Group One is. Tractor Supply will most often have them in stock. Less so automotive suppliers. If your electrical system is properly maintained, avoid going to an 8-volt. You may benefit from a 6-volt battery tender over the winter; or disconnect.
03-19-2013, 02:33 AM
I wish I could remember the old 6 Volt OEM Cranking AMPS and Cold Cranking AMPS #'s, but I understand that the Tractor Supply places do have the higher AMP rated Batteries, most Parts Store units are low rated for the more common use of Group 1 Batteries, which is old Volkswagen Bugs.
I think the last time I checked the Interstate Battery ratings were not that great.
davepink53
03-19-2013, 04:01 AM
I just put a Bond brand 6 volt battery in my Champion. It is 640 CCA and 800 CCA at 35 deg. Whatever that means. She cranks over quite well now.
STDBKR ASH
03-19-2013, 04:27 AM
HI Dave that's good the battery cranks the 53 over better now.
rknight89
03-19-2013, 08:34 AM
Farm and Fleet, Tractor Supply, Farm King or Big 'R' if you have any of those in your area should carry a decent 6v battery. I have had my best luck with Interstate Batteries. I have a distributor near me so getting one is no problem. If you're not near a distributor, any reputable interstate dealer should be able to order you one and have it in a few days.
sasquatch
03-19-2013, 12:18 PM
My NAPA store carries them. Says they sell them to big rigs where they wire four together for 24V. Mine has been in use for over five years and still going strong.
raprice
03-19-2013, 03:38 PM
Sears sells 6v batteries. I have one in my Model A Ford and it's been terrific.
Also, Pepboys sells 6v batteries too.
Rog
davepink53
03-19-2013, 03:44 PM
Hi Ash, good to see you on the forum. Yes the battery fixed my starting problems. Thanks :)
studegary
03-19-2013, 03:55 PM
Rog
Most of these common 6 volt batteries have enough power for a Model A or VW bug, but not enough for a V8 Studebaker.
j.byrd
03-19-2013, 04:27 PM
Jimmie, I have an Optima in the Anglia, it has 1000 cranking amps, 800 cold cranking amps. The Interstate and Tractor Supply batteries always did fine in my 6 volt cars, trucks and tractors while living in Tn. and Al., but the Sears Die-Hards always did just that - -died hard after just a short time. Now, I know Sears "bids out" for their stuff, so the newer ones may be the best in the world now, just my 2 cents worth, John
Jimmie
03-22-2013, 01:01 AM
Thanks for all the suggestions, now I will start looking into the various companies mentioned.
Warren Webb
03-22-2013, 01:55 AM
I would stay away from a Sears battery. When I worked there a steady stream of people came in every day with bad batteries & their warranty for free replacement always seemed to be by coincidence had expired a month or two before, so they were probably paying in their pro-rate for a new battery & cost Sears zero, plus we had to charge for installation to boot. Their 6 volt battery (which cost over $100 then) had the worse warranty- almost as bad as the cheapest one, the Plus Start which was referred to as the "Push Start" in the shop.
Blue 15G
03-22-2013, 10:47 AM
I don't have the exact specifications here in front of me, but I definitely agree that it's best to buy the strongest amperage 6 Volt battery you can get. It not only helps with cranking ability, but they seem to last significantly longer than the cheapest available, in my experience. A tractor supply store or a GOOD auto parts store are both good sources.
Dave Bonn
'54 Champion Starliner
stall
03-22-2013, 08:05 PM
My Speedster has a V8 and about 5 years ago I purchased a "Heavy Duty" NAPA 6-volt battery on the advice of forum members. It's been great with very fast cranking. BTW, the NAPA stores in my area and I think all over give you a 10% discount with an AAA card.
Good Luck, Murray
stall
03-23-2013, 11:07 AM
As unlikely as it sounds I actually recorded the info on the Heavy Duty NAPA 6-Volt battery I installed in my Speedster.
6-Volt NAPA battery #7244 Commercial unit with 850 Cold Cranking Amps
This battery has completly changed the way the car starts; it's all good now
Murray
george o
03-23-2013, 11:18 AM
Car quest also carries them in our area
Take care
George o
