pressed on rear hub
  • pressed on rear hub
    Wow, thought I would check the rear beake shoes on the 62 hawk that I just got and two days later I am still where I started. The brakes seem to work ok. Maybe I will just leave well enough alone. I do need to know the trick, if there is one, to getting these brake druns/hubs off. Thanks
    Good info right here:http://www.studebakerdriversclub.com...ar,hub,removal
    Oops,just noticed you're new to the forum! Welcome!!! This rear hub problem comes up all the time,along with a few other standard questions.
    Some times it's easier to refer to older posts by using the search button at the right hand top of this page.
    LaSalle,Il
    61Hawk
    Oglesby,Il.
      Using the "search" link at the top of the page I found this string about rear drum removal, there are more!
      Studebakers Northwest
      Ferndale, WA
        Buy the dogbone nut puller and use it......now where are those vendors in the group........
        65 2dr sedan
        64 2dr sedan (Pinkie)
        61 V8 Tcab
        61 Tcab 20R powered
        55 Commander Wagon
        54 Champion Wagon
        46 Gibson Model A
        65 2dr sedan
        61 V8 Tcab
        63 Tcab 20R powered
        55 Commander Wagon
        54 Champion Wagon
        46 Gibson Model A
        50 JD MC
        45 Agricat
        67 Triumph T100
        66 Bultaco Matadore
