Whats a fair price for a rebuilt r-2 supercharger?
supercharger
If the seller has proof of who and WHEN the "Rebuild" was done, SN-60 '63-'64 Paxton S/C's go for give or take $1000.00
A McCullough clutched unit is somewhat less.
Maybe SN-60 has some input here.StudeRich
I have a great used supercharger for sale (now that I sold the JTS engine I intended to put it on)....
I can give you an offer price if you want...
JeffHTIH (Hope The Info Helps)
Isn't the seller someone on this Forum?
To me, it looks like the bid is about where it should be ($750, IMO), but I see that the minimum has not been met.Gary L.
800-1000 is reasonable. A broken core is worth 200-300, and the parts to totally rebuild is around 600. Impeller, and oil pump is additional. Spring pack is additional. It can run over 800 in parts if it's totally trashed to start.Bez Auto Alchemy
It really gets interesting, as nowadays folks doing exact restorations are looking for SN units with the proper bearing housing for their application......Take two units in similar condition....The one with the correct bearing housing for the 'build' could be worth much more to the 'builder'!
Based on a few units I know of built by that rebuilder, the seller likely has $900 + in the overhaul.Jim
