What could be causing my 1963 Avanti R2 to misfire as it reaches 5000rpm?
Rebuilt fuel pump & carb,new fuel filter,lines and tank cleaned.
New wires,plugs,rotor,cap and pertronix & coil.
Correct timing and vacuum advance.
Idles fine with good vacuum.
Runs smooth and does not miss until it reaches 5000 rpm.
I set the valves cold and wonder if I set them to loose and this is the cause.
Bob Langer
63 Avanti
Glenshaw,PA
Bob Langer
63 Avanti
Glenshaw,PA
