On the next project on my list of things to do is service is the fluid in the Power Steering unit (P/S) and attach the new belt and go over all the lines make sure there is no leaks in the system. There is fluid in the reservoir I'm going to replace it with fresh fluid. What type of fluid do I run in the P/S unit? Would I run a cleaner through the system, what would you guys do?
And with the rear end, should I leave it alone or replace the fluid in the rear end? If I should replace the fluid what is a good type of fluid should I use that is durable and is long lasting? Thanks!
Dylan
Dylan
