Steering Column Setup
  • Steering: Steering Column Setup
    I have dis-assembled the steering column of my 1964 Daytona -(standard trans), cleaned all of the gunk out and now want to replace the shaft linkages. I forgot to record the placement of the upper linkage arm. It has a slight bend and I'm not sure if the curvature should be pointing towards the bottom of the column or towards the top.
    Any help would be appreciated.
Name:	steering lever.jpg
    Thanks
    T-cab
    Check out the parts manual. It shows how everything fits together.
      The drawing in the parts book is inconclusive. The drawing does not show any curvature on the upper lever, however the one on my car has a slight curvature as the photo shows. If somepone could check their car to see which direction the curvature is pointing to would be appreciative.
      Thanks
      T-cab
        I just went out to the garage where I have 62' and 63' standard tranny set ups with one tube and levers off the car. There is no curve in either lever arms for that lever you show. The other (2nd/3rd gear lever) does have a zig zag offset and looks very different (see your other lever). Yours is bent. As correctly shown in the parts' book...the larger diameter side of the rubber grommet is towards the shifter lever/steering wheel.....Put it in the vice...GL
          Thanks GL. I never thought that there could be a bend. The car has been in the family since new. It must have got bent sometime when the engine was removed.
          Thanks
          T-cab
            Speed shifting a 3 on the tree can bend a lot of things.........lol. Brother-in-law slammed second gear, broke the lever off and smashed the windshield in a 55 Chevy. Broke 2 fingers and we couldn't stop laughing long enough to take him to the doctor. Ended up taping all 4 fingers together and let them heal............oh, and installed a floor shift.
            1950 Champion Convertible
            1950 Champion 4Dr
            1955 President 2 Dr Hardtop
            1957 Thunderbird
