I need to check fuses for my 1960 lark. wipers, heater, gas gage, temp gauge, all stopped working. Want to check fuses but cannot find them. Anyone know where they are are.?
fuses
Tags: None
You can google "electric wiring diagram 1960 Studebaker Lark" & click/look at "images" on top left corner, I did that for my -55 but only found other years & if it's the same for you... than do as I did: ask if someone could post one here!
It saves loads of time until you've got hold of a book.
Not sure on that particular model however on a 57 SH and a 62 Lark several of the actual switches has glass fuses on the back of the switch. There could almost not be a more painful location for fuses! If the car has an amp-meter it seems wire failure is often in the wire that feeds the amp meter.Ray Stewart SDC
51 pick-up
57 silver hawk
62 lark
