I didn't have a whole lot of things going on today. Wanted to work in the garage, but don't feel to well. I have painted quite a number of vehicles in my lifetime and enjoy it immensly. I've painted vintage motorcycles, older cars, bicycles, motorcycle helmets, even some skateboards and enjoyed every minute of it.
My garage is a 24' by 30' with a 36" wide service door. I paint in there at least once a week. But the weather does not cooperate sometimes.. high humidity and cold temps hinder things. The larger projects are done in acceptable weather conditions with proper garage ventilation and the right mask. Changing the air in the garage about 6 times an hour accomplishes what I need to help protect me from explosions, fire, lung problems...things I do not want. For those of you that paint, then feel like you can't breath very well when you get done....read on.
This is the fan set up I use. OOPS wait a minute, that's not it.
This is The fan itself sits outside. And one garage door closes down on top of the duct. When your standing in the garage, all you see are two- 20" by 20" filters taped over two- 18" by 18" holes cut in the 24" high duct. The fan does not blow directly into the holes, but rather centered in the duct between the holes. The duct piece is 24"by 8" by 5 feet long. Pretty standard size at the wholesale house. I blow air into the garage under one door with my furnace fan/ductwork arraingment and out the other door, which is raised up 4" off the floor. The holes in the end of the duct are holes I have put there to slow the velocity down through the garage. I could have slowed the velocity down by raising the door higher, but dust can come in to easy. So 4" works for me.
One thing I have that you may not is a velocity meter. And with that meter the formula "Q=V times A" comes easy. All it means is your CFM or Cubic feet per minute equals the velocity times the area. I took six averaged readings under the door that was up 4". So I know the area under the door and I know the velocity. Now I can calculate my cfm's. Easy stuff------but, after 42 years in the HVAC business one would think so right?If all I've done by this article is save your lungs, your life, I would be so happy....good luck and god bless
Rick
Rick
