View Full Version : 1951 CHAMP-1960 LARK
5162
02-23-2006, 04:41 PM
DOES ANYONE KNOW IF A 1960 6CYL WILL FIT IN A 1951 CHAMP WITHOUT TOO MUCH TROBLE? ANY HELP WILL BE GREATLY APPRECIATED. THANX! AL
02-23-2006, 06:12 PM
Yes, it will. The only thing you might have to change is the crankshaft bolts at the rear. This, if you're gonna change from manual shift to automatic or vise-versa. :)
5162
02-23-2006, 06:26 PM
I PLAN ON LEAVING IT STICK, BUT ADDING OVERDRIVE. THANX!
Chicken Hawk
02-23-2006, 08:41 PM
Will a 12 volt starter turn a six volt system?
Ted
Blue 15G
02-24-2006, 09:21 AM
If the '51 is still 6 volt, wouldn't the flywheel and starter from the '51 have to be reused?
02-24-2006, 12:44 PM
Well, he didn't ask about the electrical system.[}:)] I doubt a 12volt starter would work adequately on 6 volts!:( AND, as Blue 54 Champion points out, there ARE differences between the tooth count of the starter drives and ring gears 12V vs 6V ;)
52-fan
05-20-2007, 09:00 PM
I hope you have a complete Lark engine including the correct bell housing. Some 30 years ago I bought a 1959-60 Lark service kit from SASCO and tried to put it into my 47 M-series pickup. I ran into problems because the back of the blocks were not the same. I still have the engine, but never tracked down the parts to put it in the M. The 51 car set-up might be a little friendlier though. Just my 2 cents.
!952 Champion Starlight since October,1971. !962 Daytona
since May, 2007.
JDP
05-20-2007, 10:39 PM
Use the 1950's starter and flywheel, the 6 volt starter will work fine on 12 volts.
JDP/Maryland
63 GT R2
63 Avanti R1
63 Daytona convert
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
