OK Fellas,
About two weeks ago I posted the thread about the seized engine in my 63 GT Hawk. I asked for guidance and you guys jumped in with all kinds of advise. So, for the last two weeks I have been squirting all kinds of penatrants, and release agents in each cylinder twice a day. Today ,again as advised, I crawled underneath and took a short prybar to the flexgear teeth...and it moved! I pryed a bit more and it moved a bit more. I lay under there working it back and forth for about ten minues and got it to turn complete 360 degrees! It got easier the more I worked at it.
Then I went upstairs and put the breakerbar and a 1-1/8 inch socket on the crank bolt and it turned easy there! Last time I tried that it wouldn't budge! So I added more Mystery oil to each hole and turned it some more. It felt like there was a couple of places around the cycle where it got a little tighter,(stuck valves? bent push rods?). So I am writting to say a great big THANK YOU!!!!!!!! to all of you who responded. You Guys Rock!
So now what do you think? I am thinking to pull the valve covers and check the valve train for stuck valves and/or bent pushrods. I am working on getting a carburator for it too. While underneath I noted that the transmission is blue and the tag on the readend is marked 43-13 and 3-34.
If I find bent pushrods do I need to replace all of them right away or can I just replace any damaged ones?
Thanks again for all the help and don't even think I am done picking all your brains!
Jim
Jim
