I have a three speed with overdrive and I'm replacing the rear seal. The old one that I just hooked out is nearly 3/4" long and the new one I was sent is 1/2" - is this OK? Do I recess it 1/4" or set it flush with the outside or should I get one 3/4" long? Thanks -- Nick
Overdrive seal
Tags: None
Install it flush
Originally posted by ncalder View PostI have a three speed with overdrive and I'm replacing the rear seal. The old one that I just hooked out is nearly 3/4" long and the new one I was sent is 1/2" - is this OK? Do I recess it 1/4" or set it flush with the outside or should I get one 3/4" long? Thanks -- Nick
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
Also, be sure to clean the yoke shaft real good. Then, take a piece of 240 grit sandpaper and wrap it around the shaft, put your hand around it, then twist it round & round to break the glaze and scuff the surface. This will insure the seal breaks in well and doesn't leak- hopefully !
