Grounding the voltage regulator
  • Electrical: Grounding the voltage regulator
    My charging system in my 60' Lark works fine. I've purchased a new VR, will install and keep the old one as a spare.
    The old VR bolted to directly to firewall, no rubber insulators. My new VR has rubber insulators, and a small threaded hole that says "GRD"
    I am thinking I will need a ground wire, which will attach to VR, and to? the firewall? I've doug through old posts, could not find my answer.
    Thanks..
    Howdy Neighbor (Lark-o) I have a 1958 Lark Vlll 4DR that I will perhaps rob the 259 from in the spring but the rest of the car will be offered to the members of this forum. I did tell Radio Roy He has first dibbs on the stock "White Knobbed Radio and Bezel from the car. The tranny is an Automatic. and the car was never wrecked or abused. Anyone need anything from this car lemme know.
    Patrick Sammon in Sedro Woolley Washington State
    Patrick Sammon
      I could be interested in a driver side front fender.. Are u planning on parting the car out?
        Thanks..
        Yes! You do need to ground the voltage regulator. I think the rubber grommets are there to ease the vibration to the VR, but am not sure about that. Some VR's have a metal clip that goes over the rubber grommet to ground the VR to the firewall. If your new one does not, then run a separate wire from the VR to the firewall and make sure the connections are clean. Use a heavy stranded wire, not solid wire.
          Thanks for the info, I will do that.
          Dave
            Are you sure it's the correct voltage regulator? I'm not saying it can't be, but the originals didn't have rubber insulators and I don't recall seeing an aftermaket one that did either. Why have you decided on changing it if the original is working fine? Just my two cents.
            Joe
            Thanks..
            1962 Daytona
            1964 Cruiser
            And a few others
              Hi Joe,
              I wanted a spare.. I am planning on some heavy driving this spring/summer.. I have read that a spare VR is not a bad thing to have, the one I have now, is kinda beat up, its an old American Bosch unit.. very old.. I also wanted to make the engine compartment look better..
              As far as it being correct, I went to the Bob Johnson site, there is an old VR crossover, I got the number off of this site.
              Dave
                The rubber grommets are to alleviate vibration. The best thing to do is run a dedicated ground wire from the VR right to the Gen case. This is what was done by most OEMs. The gen should have a tapped hole in the case for this purpose. The VR will NOT work without a really good ground back to the gen.
                1947 M5 under restoration
                a bunch of non-Stude stuff
                  That sounds good, I will look my gen over to find that tapped hole, is it usually in the back side of the gen? or?
                  Dave
                    heavy driving might require looking into the generator too....also, I think there is a "traveling trunk list" somewhere on what you need to carry in the trunk.....GL
                      Usually on the cylindrical part, usually near the middle or near the 2 terminal posts. Not on end.
                        Cool.. thanks..
                          Thats a good point GL, I should inspect the Gen as well.
                          I will do this
                          DB
