1957 President Classic, D44 tapered rear axle, Turner rear disc conversion (Also installed are Turner's front brakes and MC). Rear axle recently overhauled with new seals throughout. Bearing preload set IAW the factory service manual. There are three shims on the right side and none on the left.
With the car on jacks, three of the wheels spins freely, with just a little "ching" from the pads on the disc. When I spin them by hand, they keep rotating for a turn or so. The left rear wheel, however, doesn't take much more effort than the others to turn, but there's a constant brake dragging sound and it stops spinning as soon as I stop turning it. From under the car, I can see that it's the outer (static) pad which is rubbing.
My initial impulse is to shim something, but as any shims under the bearing would move that axle outboard (closer to the rubbing pad), and since the caliper bracket mounts to the inside of the outer bearing flange, any shims under the caliper bracket would move the caliper inboard (also the wrong direction).
Before I start shaving material off the caliper bracket to move it outboard, does anyone have any better ideas?
I guess I could just live with it until that pad wears down a bit...
