What would be the correct shock number / type for the front my car ? I'm working on getting my 52 commander stance looking right. It's modified as some of you know and I believe the front is about two inches lower than normal. I currently have seven inches ground clearance at center of the front cross member. (to the cast iron chingus)
I want it slightly lowered without the slammed look so as not to compromise the ride. I took measurements at the wheel wells and in the rear to the bottom of the fender at center of the wheel it is 20" and in the front in the same spot it measures 25.
Can anyone compare this and let me know what you think ???
Thanks in advance,
Dean.
Thanks in advance,
Dean.
