Here in the Bayou State (Louisiana) we are 77 feet above sea level. We are planning on heading "way up Nort to dem Colorado Spring) this summer. Do I need to be concerned about carburetor adjustment when I reach the altitude of Colorado Springs?
Do I need to adjust carb for altitude?
You should probably at least adjust your idle speed upwards. It would not be a bad idea to adjust your mixture screws as well for smooth running. Maybe some of the local folks CO can chime in.Pat Dilling
Olivehurst, CA
Do a search for the post entitled "R2 Carburetor altitude Adjustments". Lot's of comments and opinions. I'll repeat here Carter's rule of thumb for AFB's - Above an altitude of 4000 feet, reduce primary jet size by .001" for each additional 1000 feet. Therefore, for an altitude of 7000 feet, the primary jets would be reduced .003". This would be more easily accomplished with a step-up rod increase, if you can find one the yields a comparable reduction in mixture.
Originally posted by mjeansonne View PostHere in the Bayou State (Louisiana) we are 77 feet above sea level. We are planning on heading "way up Nort to dem Colorado Spring) this summer. Do I need to be concerned about carburetor adjustment when I reach the altitude of Colorado Springs?Last edited by Welcome; 01-20-2013, 08:13 AM.
Yes, you can put in "fatter" metering rods. It takes about 30 seconds per side for an AFB. WCFB's are just about as easy. Strombergs......not so much.
They can tolerate a bit more timing at altitude.
You may need to turn in the idle adjustment screws a little. (there are no "air adjustment" screws as mentioned earlier)
You'll lose a bit of power at altitude, but on the bright side, octane requirements are lowered.Last edited by bezhawk; 01-20-2013, 09:08 AM.Bez Auto Alchemy
Went from Mich to Wyoming with my street rod.Adjusted idle stop. No problems. Ran a little rich, but we wern't there long enough to bother with.
B0bOwn \'53 Commander Starliner. Red w/beige top. 350 Chev/700R4. Tilt,cruise,A/C.http://i76.photobucket.com/albums/j30/Bobphyl/StudeontheBeach.jpg
When I took my 52 to Estes Park back in the 80s all I had to do was open up the choke. It would barely run when cold in the morning with the choke closed."In the heart of Arkansas."
