Looking for source for molding clips that attach stainless 2 tone break trim on 61 Hawk fins. Don't have one to go by but part number is 1338902. SI does not carry them. Thanks David
Trim clips
Tags: None
David: Probably the hobby's largest purveyor of trim, screws and clips is Restoration Specialties & Supply of Windber PA.
Phone: (814)467-9842
Website: www.restorationspecialties.com
Good luck. BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
You need to know if you are looking for the tiny clips for the UPPER Moulding or the larger ones for the larger Lower Fin Moulding.
Both are Paintline Mouldings.
Suggestion #1: If you only looked in S-I's Catalog, you really need to contact them direct! Best guess would be S-I only lists 20% of ALL the different part numbers they have in stock in their catalogs!!!
Suggestion #2: Contact the SNM Archives and order a copy of "Clip" drawing 1338902. You'll then know what that "Clip" actually looks like on the drawing ...will likely have the Studebaker vendor name & their part number listed on it ...and if you get really lucky, it may turn out to be the "same as" a different but available Studebaker part number "Clip" having just have a slightly longer stud, etc.
Good Luck!!!
