Quick easy one - I recall in removing the old cork float sending unit that the float sits near the front of the tank, at the tallest/deepest point of the tank. The unit I have now, a SW improved version, screw mount holes line up best with the float facing the rear of the tank. this is my 66 cruiser, and I am finally getting correct signal to Temp and Gas Gauges, after removing the original - faded like the palm springs sun can do to a gauge face, and then trying another gauge cluster with no results, until now, with another good gauge cluster. This means I can drive without running out of Gasoline! (done it once, never again!) So - Which direction is correct? float facing forward, or rearward?
Thanks in advance to all. fred
