Hello!!
After reading for awhile I wanted to jump in here. I reciently moved from Dallas, TX to Sioux Falls, SD to expand our business and as it took many years to totally get out of my excessive Corvair hobby, I vowed to never deal with old cars!
Well years ago at a swapmeet I was working in Arlington, I set eyes on a perfect 1960 Lark wagon and have been interested since. Now that things are going well I discovered Studebakers again when searching for a good Wagonair but fell for the C& K bodies.
I now have in my posession a decomposed 55 Commander with a 259. Got what I expected from Ebay and have my work cut out.
Compared to Corvairs I'm pleased to see the increadable parts availabilty.
As I am stocking up on boody parts, panels and trim I am preparing to get the frame cleaned up, then mid winter have a slot for the body shop. I already have lots of questions so thanks in advanced if anyone cares to help! So far the only parts I am in need of right away would be a center crossmember which support the body supports inder the door hinge pillar.. Rust has sort of split it apart. Is that lower part available? It's the one that goes from one side to the other.
Also I need a 55 grille. Wish me luck there eh? Mine is severely pitted and that pot metal - I cant see how a chrome shop could repair that but I could be wrong?
Also I thought I wanted to convert the 3-speed to a GM 700 transmission w/ OD but perhaps I should keep the 3-speed w/ overdrive? I didnt know this car would have that (OD) but is it quite desireable?
I will be building this engine for endurance and efficiency thus it will have ported fuel injection. But right now I need to get the frame repaired then the body.
Glad to see all the brake kits, dual master cyl fits, front suspension updates, etc..
I am thinking about either attending the Rockford, IL meet, Pikes Peak, that Wisconsin swap meet or the Denton, TX meet. hope to find some stuff I need at one of those and see how the interriors come together as there is none in this car.
Hope to meet some of you one day soon!!
Ches
Ches
