I need to know what transmission fluid to put back in the transmission...I do not want the wrong type fluid for sure...Thanks
1955 Studebaker Commander / DM 250 Trans Fluid Type?
Be sure to change ALL of the fluid. The torque convertor has a separate drain. ALL of the fluid in the unit should be the same.
Put five quarts in.
Idle engne for about one minute in L.
With engine still running and in Low, add another three quarts.
Then add enough to bring it up to the Full mark. Do not overfill.Gary L.
64V-K7:
Dextron III-Mercon is still used in the 55. 28,000 miles later it still works well. 96805 miles on her now.
Just did an 80 mile round trip this evening,,, smoooooth,,, like butter.
B Murrey:
To drain the torque converter, remove the converter housing cover, at the front of the trans, rotate the converter till you see the drain plug.
You should also remove the oil pan and clean the screen assembly. The screen assembly is "Not Available" as far as I know so clean and reuse it.
Don't believe the local parts houses if they tell you they can get the oil pan gasket. They will give you one for the 56 and later trans. It doesn't fit.
Go to a Stude Vendor for that part.South Lompoc Studebaker
