Looking for the right size wheel bearing nut wrench and brake drum puller for my 2R10 pick up. Where's a good place to get these tools and does anyone know the part numbers?
2R10 pick up rear wheel bearing nut wrench
Looking for the right size wheel bearing nut wrench . . . for my 2R10 pick up.
Hope you are more lucky than I've been. Seems most CASOs don't have this socket and put the wheel bearing nuts on and off with a cold chisel, thus ruining the nuts. Again, the good news is they're cheap and the nuts, seals and bearings are readily available at truck shops.
Looking for the . . . brake drum puller for my 2R10 pick up.
jack vinesLast edited by PackardV8; 11-24-2012, 02:37 PM.PackardV8
Originally posted by PackardV8 View PostIIRC, your 2R10 has the Timken axle and would use the same wheel bearing nut wrench as my '55 E12. The good news is it is the 2-3/8" and very common at truck and 4WD shops; the same as Dodge, Jeep, Ford, Chevy 3/4t using the Timken or Dana 60 rear axles.
BTW, are you thinking about 1/2t? On larger trucks, when the nuts are removed, the rear drums just pull off, same as front drums, just larger. No puller necessary.
jack vines
KD Tools sells these at most good auto supply stures (O'Reillys, AutoZone, Discount Auto parts.
KD Tools - Spindle Socket
Part # 2432 2&3/8" socket
Line: KDT
KD Tools - Spindle Socket Part Number: 2432
Line: KDT
- limited lifetime warranty
- UPC: 82171024320
- 2-3/8 Inch Hex Socket
Detailed Description
Wrenches remove 6 and 8-point spindle nuts on trucks. Turn with 3/4 inch square drive tool. Depth: 2-7/8 inch Wall Thickness: .200 inch Overall Length: 3-7/16 inch.
Caution: Do not use with power tools.
Manufacturer Information
Since our 1919 beginning, KD Tools has been driven by innovation. From our first specialty tool, the Model-T valve spring lifter, to our latest Ratcheting Puller, we've built our reputation with tools that make tough jobs easy. That's why we are the first choice for thousands of automotive technicians worldwide.
Originally posted by crash620 View PostLooking for the right size wheel bearing nut wrench and brake drum puller for my 2R10 pick up. Where's a good place to get these tools and does anyone know the part numbers?HTIH (Hope The Info Helps)
