I've seen (and used) three different grits of stone to re-surface engine cylinder walls. What are those three grits?
Studebaker 'Tech Trivia' Question #5
To: DEEPNHOCK,------ I wouldn't disagree with four, but 80?..OUCH!....and 500...why bother? I've used 180, 220, (which believe it or not I'll be using on a 259 in about ten minutes), and 300 grit.
I'll say You have CORRECT ANSWER here though!
That 80 grit would have come in handy with Jim McCuan's block a while back...
Truth be known, these four grits are what is offered in the hone stone catalog.
I don't know if the top and bottom would be my choice either...
Originally posted by SN-60 View PostTo: DEEPNHOCK,------ I wouldn't disagree with four, but 80?..OUCH!....and 500...why bother? I've used 180, 220, (which believe it or not I'll be using on a 259 in about ten minutes), and 300 grit.
I'll say You have CORRECT ANSWER here though!HTIH (Hope The Info Helps)
