(I write this with a little trepidation.....)
Why is there a fire extinguisher in this picture from an hour ago?
Just had an 'event' while working on the Yellow POS.
Let's just say that there was a fuel leak....and a spark....and a fire.
It was a BIG fire (well, it sure looked big when it was 18" in front of my face.
The whole backside of the engine and firewall went up in flames.
I moved faster than I have in a long, long time.
Right to post#1 in the shop.
Never unlatched the fire extinguisher. Just ripped it right off the post.
Took the whole thing to get the fire knocked down and put out.
Then the hose came out and washing all the powder started.
After cleaning everything off the search started for the gas leak.
Now, I had just test started it to see how it ran with bigger new jets and rods in the new 1403 Edelbrock carb.
Ran great until it blew up...
In searching, I found out one of the two banjo bolt washers for the fuel line to the carb had broken and it folded over a little bit.
This allowed gas to spray out against the carb body.
I didn't see it or smell it as I was setting in the drivers seat.
But it must have leaked bad enough to get gas on the bellhousing, as that's where most of the fire was coming up from.
In retrospect (now that my heart rate and blood pressure has settled down) I am not real mad.
Not mad because there is very little damage.
Some burned wires down by the starter. A burned wire by the intake manifold.
The plug wires are nasty looking.
There's some soot damage to the underside of the hood.
The one cross bar burned the paint pretty good.
It's all fixable.
But it happened in the blink of an eye.
If it had happened on a test drive down at the end of the driveway? Who knows.
But it happened at the shop door.
And there are six fire extinguishers all at the ready.
One lucky guy. But being ready is part of it.
Are you ready?
Food for thought....
