I have been noticing that at slow speeds the camper is making a slight noise and I think I feel a little vibration in second gear only. So to help diagnose the possible issue I drained the oil out of the trans today. It did contain just a trace amount of fine metal filings and two flakes of metal. They are not magnetic and seemed to be soft metal like bearing babbit found on thrust washers. The biggest piece was about the size of small oatmeal flake. The other one was very small. So anyone ever work on these and know if there are thrust washers in there? Oh, it's a T86 with overdrive R11. I will be removing the trans for teardown and try to figure out what is shedding metal. The crazy thing is the trans works great including the OD.
Dan
Dan
