Started to tear into the hawk today to get it ready for the restoration.Why is it they alway look worse in day light then they did looking under them in dim light. The body shell will need a lot of baceing before it comes off the frame. I knew the shell was rough but this is going to take some major work. The rockers are gone with just a peice of angle iron welded in with the rocker mldings covering them up. The inner rear fenders are missing on the lower 3-4" as well as the uppers where the fender bolts at the roof line. Floors are all fiberglass at the inner fender under the back seat. Oh well I wanted a 64 I guess I'll just have to make the best of it. AS they say SUCK IT UP BOY.
64 hawk restoration
Originally posted by swvalcon View PostThe 1/4 panel someone just put a peice of tin over the bottom at the lower behind the door that will all have to come out. Once the paints off I'll have a better idea of what I have to work with.
When you get it finished, it will all have been worth it. Good luck!sigpic
In the middle of MinneSTUDEa.
Originally posted by Milaca View PostI actually thought the rear fenders were in great condition, I had no idea that this fender was patched. I'm feeling better and better about having sold this car.
Brent. At the very least I'll have some great before and after pictures for my restoration scrap book. As long as I've been doing this very few are easier than you think so nothing new. I'll agree with you I thought the body parts where pretty clean myself. I dug into the 1/4 tonight and will post pictures tomorow. Really hacked up on lower front. I knew what was there for rocker panels so that was no surprise. Knew the shell was rough but as I said when you get into the day light it kind of slaps you in the face.
I've fixed much worse. Believe it or not, many of these parts and panels fall in to the realm of finite resources.Brad Johnson,
'56 Sky Hawk in process
Mo offense intended but it might make a better parts car so that better ones can survive. You can always swith the tags. cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Originally posted by 8E45E View PostWhat kind of a comment is that! ANY '64 Hawk deserves to be saved!!
That rot behind the qtr panel looks all too familiar. The "good" thing about is is you won't need to finish off the repairs to perfection as they get hidden under some undercoating when the fender is back on the car.
Your a braver man than me fixing the fender bottoms though. I elected to locate solid replacement ones and even those had enough dings and scraps on them it took seeming forever to hammer/fill/block them out. I was not confident I could weld in a patch and get the curve right on the originals.
Jeff in ND
