Being a first time Stud owner , every problem seems insurmountable untill a find an explanation on this site. I have now sorted my suspension problems , left rear sping hanger bolts were loose , oil leak through the crank shaft pulley also sorted when I found that the wrong woodruff key had been used and allowed oil through the keyway.Mycurrent challenges are ;
1. My 58 silverhawk came with a modified overdrive and seems to operate as follows, it engages od from start up and there is a switch on the gearlever that is supposed to disengage the od. Needless to say it doesnt work. Before installing an original system i would like to understand the problem. What happens is the following,at start up the od partly engages in so far that the car will freewheel in gear but the gear ratio is the same as when the od is not engaged! When i press the switch on the gear lever the engine momentarily switches off and comes back on when i release the switch, this action is supposed to disengage the od , which of course it fails to do.If i hold the switch down , the engine cuts out and has to be restarted at the key ??????? What is happening ?
2. Can someone explain in idiot terms how i wire up a rev counter, tachometer .
Thanks for all the great assistance
