View Full Version : What is the hardest Studebaker Fuel pump to replace??????
unclemiltie
10-10-2012, 03:34 PM
What Studebaker has the hardest fuel pump to replace?
I just had to replace a fuel pump on a 50 Commander. It has 4 lines going to it, is hard to get onto the engine, you have to stand on your head to work on it and the clearance is not much. Getting all those fittings put on without crossing threads was a challenge. While working on this one definitely considers the merits of an electric pump and forgetting about the pump driving the wiper motor.
This is harder than any V8 or champ 6 fuel pump I have replace.
Any other hard Studebaker pumps to replace?
53k
10-10-2012, 04:02 PM
'65/'66 V8 pumps are pretty mean with that stupid plunger you have to make sure doesn't get away and they are awfully tight to the frame. I gave up on a '65 Cruiser and went block-off plate and electric pump.
Studebakercenteroforegon
10-10-2012, 04:10 PM
All you have to do on '65 - '66 V-8's is remove the sub-plate (behind the fuel pump mounting flange) then remove the fuel pump push rod, smear it with some grease and re-insert it. The grease will hold it up out of the way so you can readily install the fuel pump. Almost any auto parts store will stock the gasket that goes between the sub-plate and the block.
41 Frank
10-10-2012, 04:38 PM
While putting a fuel pump on a small block Chevy motor can be frustrating exercise, the easiest way to keep the push rod up out of the way, while you bolt up the pump goes like this. Most earlier Chevy small blocks have the drilled bosses present at the front of the block where in the mid fifties Chevies had their front motor mounts. These bosses still have the holes drilled and tapped. One hole will have a bolt stuck in it as it is open to the fuel pump area, to prevent oil leakage. Remove this 3/8ths x 1" bolt and temporarily replace with a 1 1/2" bolt. Screw this in finger tight until it contacts the fuel pump push rod and it will hold the rod in place while you bolt up the pump. (Pump will install easier if the rod is on the low side of the eccentric, rotate engine to accomplish this). Reinstall original short bolt when finished. Makes it about a 15 minute job.
HyBall
10-11-2012, 05:26 AM
65/'66 V8 shoe are pretty impart with that dull swimmer you bang to piss trusty doesn't get away and they are awful waterproof to the framing. I gave up on a '65 Car and went block-off sheet and electric ticker.
deco_droid
10-11-2012, 10:12 AM
Hopefully you don't have two more to go! :)
By the way, how many miles were on this one and what was the problem that caused you to need to replace the fuel pump? Just wondering in case I ever have this issue...
SN-60
10-11-2012, 10:36 AM
I've found that unbolting the power steering pump on Studebaker Avantis and C/K's with p/s, and resting it on the engine (with hoses still attached), is a lot easier than trying to work around it
on a V8 fuel pump replacement.
unclemiltie
10-11-2012, 06:01 PM
This 50 commander has 53k on it. I previously replaced the fuel pump a couple years ago. This one was pumping oil out the vent holes. This winter I am going to rebuild one with the more modern kits the vendors sell. I assume the newer gas is not agreeing with the 1950 era rubbers in the pump. Both replacements were NOS pumps.
mbstude
10-11-2012, 07:59 PM
Milt, any chance you could post a pic of the Commander pump? I've got two NOS pumps with the extra stuff for the wiper motor. And I don't know if they're for a Champion or Commander.
Bob Andrews
10-11-2012, 08:41 PM
Sentence of the year.
TomB
10-11-2012, 09:58 PM
I did not understand that sentence at all actually. Translation???
Bob Andrews
10-11-2012, 10:46 PM
It is completely un-understandable. At a level never seen before. No one else has come close. Thus, sentence of the Year.
SN-60
10-11-2012, 10:55 PM
HyBall gave up on the mechanical fuel pump in His '65 Studebaker. He then put a block off plate on the engine, and installed an electric fuel pump. (ticker)
unclemiltie
10-12-2012, 07:33 AM
Matt, Is there a number on the pump on the side of the flange where it mounts? If so post it and I will see if it is in my old fuel pump catalog and can hopefully tell what it fits. The late forties commander vacuum pumps look similar but the filter has a different angle. You can actually remove the screws on the top and rotate the pump to work just like you can for the later 6 cyl pumps.
If there is not a number on yours I will post a picture
warrlaw1
10-12-2012, 10:10 AM
I was thinking Hyball was using a google translator. English to another language and then back to English. I played with it when emailing a Mexican sweetie. Sent her $300 and never heard from her again. Later found out she got married and I paid for the wedding. Never trust a translator.
deco_droid
10-12-2012, 12:52 PM
Ah, ethanol strikes again! If I ever encounter this I suppose I will go with the new kits as well...
oldwood
10-13-2012, 07:21 AM
I pulled the oil pan off of the engine that is going in my '57 Transtar to inspect everything. It came out of a '50 Commander. I notice the fuel pump had been replaced . The bolts that secured it where almost touching the camshaft. So be sure and not just use any old "long" bolt because of clearance issues with the cam.
oldwood
10-13-2012, 08:14 PM
I made a mistake on my engine info. It came out of a Champion. I'll try and post a pic of that problem.
deco_droid
02-27-2013, 12:05 PM
Looks like this was my problem after all, so I am in the market for either a rebuild kit or a new pump for my 50 Commander. I see in the shop manual that there are about 50 parts to this thing, but can you change out the old rubber without taking everything apart? I am somewhat mechanically inclined, but I just don't want to get in over my head...
dong
02-27-2013, 09:07 PM
I remember a few years ago when one of our members posted a very garbled message and a lot of people made fun of him and posted some pretty vicious replies. Turned out he had had a stroke. there were a lot of I am so sorry etc replies. I hope this won't be a similar situation.
G T Joe
02-28-2013, 08:41 AM
I think that ANY fuel pump on a Studie is as easy as pie compared to some late model pumps I have changed on the new breed of cars out there !
deco_droid
03-13-2013, 01:59 PM
Sounds like what happened with mine... what vent holes are you talking about though?
