StudeGary mentioned in a recent post that the HD Avanti 6-blade fan shortens the life of the water pump. The HD fans are indeed noisy and keep my Avanti around 180 degrees, but I recently bought an original 5-blade (offset) fan to see if the noise reduction will adversely affect cooling ability. A bonus would be improved water pump life. Since I am new to the Avanti world, I wonder what is the basis for the statement that the HD fan reduces water pump life? Inquiring minds...thanks for any info...Bob
Avanti HD fan affect on Water Pump
Originally posted by SN-60 View PostTO: AnAvanti4Bob,------If the HD six blade fan is in good condition (not bent and in proper balance) I really don't see how using it would have any effect on the life of the water pump.
TO: AnAvanti4Bob,-----One of those inexpensive lawn mower blade balancers would probably tell the tale as far as balance, as far as whether or not the blades are in the same 'plane' I would just
lay it on a known flat surface and see if the blades touch evenly......OR, if it's still on the engine,...manually spin it in relation to a fixed object (or constant) that the blade clearance can be measured against.
Even if the fan is in balance, there is still a major increase in the mass whirling around at the end of the water pump shaft. Of course an out of balance condition would also add side loading to the water pump bearing.Gary L.
To: studegary,------Nope,....a slightly greater 'mass', if the fan is in proper balance, would have no discernable effect on the water pump bearings. In 'Chucks Stude's' case, I doubt if it was the extra blade
on the new engine fan that caused his water pump to break in half.
There is also the gyroscopic effect of heavier fan blades mounted on a thermostatic fan clutch located farther away from the water pump housing and bearings inside the housing.
Anytime the car accelerates, decelerates, turns left or right or bounces up or down, the gyroscopic effect induces additional loads on the water pump bearings and housing.
The gyroscopic effect of spinning objects can be seen and felt by holding a front bicycle wheel by the axle ends, have someone spin the wheel and then turn the spinning wheel left, right, up, down, etc while holding it by the axle. You will have to use noticeable muscle power to control the spinning wheel. The faster it spins the harder it is to control.
In addition to the simple heavier overhanging load of a heavier fan placed farther forward, the gyroscopics add additional loads and together they affect the water pump life.
Larger and more varied forces acting on a longer lever.
Originally posted by SN-60 View PostTo: AnAvanti4Bob,------I think I'm outvoted here.....Beware of HD engine fans!!
Originally posted by Don Jeffers View PostThere is also the gyroscopic effect of heavier fan blades mounted on a thermostatic fan clutch located farther away from the water pump housing and bearings inside the housing.
