Good morning. I need to locate a choke cable to manually operate the 1-barrel of my '51 Champion.
Carb rebuilder tested it and it worked for him on the bench, but won't open for me.
I cleaned the hot air tube going to the exhaust manifold; it fit kinda loose into the manifold but
even putting a bit of high-temp gasket sealer where the tube exits the manifold didn't help.
Somehow, I'm not getting sufficient hot air up to the choke and ran out of ideas how to fix it.
Choke spring is intact and the choke works if you turn the choke by hand (linkages are okay)
but it never moves from where you manually set it.
I have an open dash switch hole where someone had previously had some kind of toggle switch
(maybe fog lights?) I could use for a manual choke.
Was there a manual choke option in '51, so I could use an original-looking choke cable instead
of buying a generic one? Anyone got a complete one they'd sell?
Regards,
Clarence
Regards,
Clarence
