Do the four nuts bolting the carb to the intake manifold use washers, lock washers& or flat washers? PO used none.
Carberator hold down technique
What Joe said....
Always use small (SAE) flat washers so you don't chew up the ears on the carb. You can still use a lock washer.
quote:Originally posted by curt
Do the four nuts bolting the carb to the intake manifold use washers, lock washers& or flat washers? PO used none.HTIH (Hope The Info Helps)
Good eye....
WCFB = White Cast Four Barrel
AFB = Aluminum Four Barrel
I have a new gasket between the carb and the intake manifold. Base of carberator seems to be an iron compound.HTIH (Hope The Info Helps)
Interesting....
More urban legends on my part?
Or, maybe it was Al Carter?
Beats me... I dunno...
I heard it that way from a Stude guy in 1969, so you know it has to be true and accurate[|)]
quote:Carter had been manufacturing the model WCFB four-barrel in the early Fifties, and General Motors began using the "William Carter Four Barrel" as standard equipment in 1952, with Packard picking this type of carburetor as its stock equipment choice in 1953, followed by Chrysler in 1954.
quote:Because these "White Cast Four-Barrel" carburetors had jets and metering rods that were on the money, performance of the optional 270hp 283 was very good.
Well I'm confused.
David
You're confused?
I thought I was wrong, but that was a mistake
Well I'm confused.
DavidHTIH (Hope The Info Helps)
