I purchased the templates for the seatbelt installation in front and rear of the "Hawk" and "Lark" cars, applicable to early 60s? (by they way, I'm using NOS Stude-Packard belts from ~early 60s, NOT the door-mounted type offered in '57)
Wondering if there were any changes in either the
a) seat rail location between a a 57 Golden Hawk and later Hawks?
or
b) any reason the seat belt anchors would be offset differently?
If I used the template measurements, the "spot" to drill is significantly away from the line of my seat rails. Where-as in the drawing in the template, if you use the same measurement (11" in from door sill I think?) it is directly behind the seat rail....
I know it doesn't sound like a big deal, "try it and see", but I've got hog troughs to drill through (and then have to weld up and grind and finish again) so only want to do this once. Will probably cut out one of my cross-braces so i can install the front seat and just make sure it wil slide through without binding on something, but thought I'd ask in case anyone has done a 57 Hawk and noticed this offset in location between the template drawing and the 57 seat rails, and know if it MATTERS or not.
thanks!
or
thanks!
