Aloha; My muffler scrapes on a spot in my driveway(can't change).What is nornal height for a 55 Commander cp.has anyone added leaves to rear springs and is this a good idea?Also,if I raise the back I'll want to raise the front.From my youth I remember little rubber(thingies)that wedged in coil springs to add boost.Has anyone tried that and does it work and are they available?I'm looking for a solution with out major rebuild. Aloha---Jim Ayling---808 521 2871
muffler scrapes
Tags: None
Them little rubber things mess up the spring rate. Does you muffler drag any place else? Someone will come up with the normal ride height. If the rear is sagging you can simply add a leaf with an add a leaf kit or get some rear springs......If the height is right get you mufflers tucked up higher.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
