Hi All - I just got a 63 GT Hawk with 4 speed manual trans. Previous owner has said that the engine rear main seal has been replaced along with the clutch. The problem is that it won't shift into reverse unless you quickly pop/slam it into gear or else it will grind and not go into gear. I have started just shutting the engine down, putting it into reverse and with clutch in start the engine. Obviously this isn't right. Would the clutch replacement be the cause or is more likely that the trans has a problem. I have literally had the car for 2 days so I haven't had alot of time to figure it out. Any advise would be appreciated. JimO
GT Hawk transmission problem
Transmission / Overdrive: GT Hawk transmission problem
1963 Avanti R2
1951 Champion Convertible
1953 Commander
1957 Golden HawkTags: None
If he lost the dowel pins holding the bell housing in alignment with the block, then a miss alignment will cause the very same problems you describe. It could be a simple adjustment. Often the clutch pivot has a piece of spring steel that cracks and you cant adjust things till it's fixed. Also there is a coupling to the bell housing release lever that is a sleeve with two clevis pins through it. That piece wears, and the pins break inside without showing on the outside. Then the release lever inside the bell housing that pushes on the throw out bearing has two fingers that engage the bearing. They are splined to the shaft, and lightly brazed. Often the thin braze junction breaks, and the fingers rotate on the shaft, instead of pushing on the throw out bearing. Hence, you adjust the free play, and it still doesn't work properly, because it is slipping (or may be slipping).
These are the typical things a non Studebaker mechanic doesn't know to look for.Bez Auto Alchemy
To: n29we,---- Also, a damaged pilot bushing--or input shaft nose can cause 'drag' on the input shaft where it should ride free. (This is a more common problem on older vehicles than folks think...and it
can drive You nuts till You find it!!)
