Hi Folks,
I have installed a Dana 44 from a factory disc brake car into my F4 Commander. (11" drums)
The emergency brake cable attachment to the backing plates is different. The cable from the F4 has bolt-on "clips" at the backing plate to hold the cable in position. (TOP in picture)
The backing plates on the "new" rear use pop-out "tang" connectors on the cable. (BOTTOM in picture)
I had originally thought that I could drill and tap holes in the backing plate and use the original clips, but the backing plate is not flat enough in that area to do that.
Any ideas on how to attach these?
Thanks in advance for any help.
Doug
Doug
