So I pulled up to a stop sign recently, and the car acted like it was frozen in neutral. It would not go into first, nor into reverse. I tried a few more times, and it finally engaged first gear. I limped the one mile home, with a knock that sounded like a rod bearing. Later I fired it up when I had time to diagnose, and it drove just fine, like nothing was wrong. Then it did the same thing again.
To make a long story short, I disassembled the transmisson last night, and found broken up bits of needle bearing scattered everywhere in the main tranny case. Upon further disassembly, I determined that they were the needle bearings that normally reside inside the cluster gear.
I've now ordered all the numerous parts that will require replacement. Before I re-assemble, I'm thinking about the future, and wondering why those bearings would have disintegrated in the first place. Because they live inside the cluster shaft, and are bathed constantly in oil, it seems like they would last pretty much forever, but these obviously did not. They actually wore through the thrust washers and worked their way out of the cluster gear/shaft assembly into the rest of the tranny.
Any thoughts? (yeah, I know: "pics or it didn't happen." You guys know I'm normally good for some carnage pics: http://forum.studebakerdriversclub.c...hlight=carnage )
