I installed a new Edelbrock 1403 on my 289 last winter. I ran the engine quite a bit and it ran great. Nice and smooth. Then I got started doing some rust repair work and then had to go out on business for most of the summer. Long story short, I neglected the car for about 3 months, during which time it wasn't started at all.
Today I started it again for the first time and it was very rough. After it warmed up it smoothed out a little but still no where near as smooth as it was back in the winter / spring. When I first tried to start a few days ago I discovered that the solenoid had failed and was holding 12V on the "I" terminal all the time. This back fed through the coil resistor and was keeping power on the electric fuel pump. This resulted in a very flooded carb.
My assumption is that during the 3 months of neglect, the gas evaporated out leaving a varnish that caused the needle to stick open allowing the fuel pump to flood the carb.
While trying to determine the cause of the rough idle today, I noticed that the jet on the right side was dripping fuel down the throat of the carb every time I opened the throttle a little. It would also backfire through the exhaust every time it dripped liquid gas. It seems this was only happening on the right side. I could never see it drip fuel out of the left jet.
Again, my assumption is that the gas evaporated out leaving a varnish, and that is causing my problem.
This is my first Edelbrock carb so I don't know anything about them. I am hoping a little carb cleaner added to the gas will clear this up. If not, I guess I have to pull it apart. How difficult are these as compared to a Holley? Any tips on does and don't if I have to pull it apart?
Thanks
Wayne
Thanks
Wayne
