Front Vent Window Latch removal
  • Interior: Front Vent Window Latch removal
    I did a couple of searches but if it has been covered I must be missing the magic words.
    The latches (little handle you twist to lock/open) on the front vent windows on my 53 C are pretty gnarly so I'd like to remove them so I can either source replacements or get these rechromed. I see a little pin or screw that goes through the side of the assembly, but can't tell what it is or how to remove it.
    Is it a set screw and I simply need to clean it up a bit? Or is a pin I need to drive through?
    Of course the windows are cracked too so maybe I should just replace both entire assemblies with ones in better condition and not worry about it (if you happen to have some that are pretty. . .)
    Dave Nevin
    Corvallis, OR
    1953 Champion Deluxe Coupe
    Stud-e-venture blog
    There is a roll pin that holds the latch handle. Drive it out to remove. There's a spring washer behind it; don't lose it!
    Removing the whole latch assembly just involves grinding off the rivet heads that hold it to the window frame.
    This would be a good opportunity to get those frames re-chromed!
    Brad Johnson,
    '56 Sky Hawk in process
      I think my car didn't have chrome frames--it is the very base model.
      Thanks Brad. I appreciate your help.
      Dave Nevin
      Corvallis, OR
      Stud-e-venture blog
        On my 62 Champ i want to get the vent window frame rechromed if i grind the
        rivets off is there a place that sells rivets like the orignals.
          SI has the chromed rivets for a buck a piece if you want authenticity. For serviceability I've used brass brake lining rivets.
          Brad Johnson,
            excellent. The shiny bits (ok, the to be shiny bits) have been removed with no loss of limb. Thanks again.
            Dave Nevin
            Corvallis, OR
            Stud-e-venture blog
