I got the 64's rear end where I could see it today. It has a tag on the bottom lt cover bolt but even after cleaning you can't read it. What was the stock gear ratio on the power shift auto? Also the lt side studs are marked R shouldn't they be L?
64 gt rear
Tags: None
3.31 would have been the standard ratio and 3.73 would be the optional ratio. Studs are supposed to be all right hand on 60's era Studebakers. Studebaker stopped using lh thread in the mid 50's sometimes.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Steve, I have a hub puller that you can borrow. It is made just for this type of brake drum & hub assembly. If you try to remove the drums from the hub, you may damage something whereas removing the drum & hub together will save you some headaches. I found this out the hard way!sigpic
In the middle of MinneSTUDEa.
Would a 3.31 give better gas mileage or the 3.73, everything else equal.
IF...this car was an around town car, no, the 3.73 would return better gas milage.
IF...this car spent most of it's time over 55mph, then the 3.31 wold be better.
IF...the freeway trips were short (maybe 20 miles or less), the 3.73 would still (most likely) win the milage contest.
IF...the freeway trips were long and fast (over 70mph), the 3.31 would win out.
See how this is going...?
