Does anyone know where the safty switch is locted on a 64 hawk with floor shift? Is it on shifter or on the trans? Starter works but only if you jump it under the hood.
Neutral safety switch
Tags: None
Not sure if you mean a PowerShift auto or a 4-speed........but on both of these the neutral safety switch is located on the shifter assembly.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
Did you get up under there to see why the shifter isnt traveling easily from Park to Drive? Last year it was easy to move the shifter but now it takes much more effort. Perhaps there is a woodchuck (groundhog) carcass up in there.
Glad you found the horn button, too bad a previous owner replaced the hi & low horns with twin clown horns though.sigpic
In the middle of MinneSTUDEa.
