On a 64 hawk tt rear end I'am asumeing its a dana 44. If you pull the rear pinion yoke to replace the seal do you need to reset the gears or can you just replace seal and retorque the nut?
44 dana tt rearend
Tags: None
Originally posted by swvalcon View PostOn a 64 hawk tt rear end I'am asumeing its a dana 44. If you pull the rear pinion yoke to replace the seal do you need to reset the gears or can you just replace seal and retorque the nut?
Bob
Originally posted by swvalcon View PostI'm assuming its a Dana 44.Brad Johnson,
'56 Sky Hawk in process
Doesn't matter what axle....no, just retorque the nut.
Normally, you want to go to a slightly "lesser" torque value so you don't crush the "crush sleeve" farther than originally required.
I'd go at least a coupla ft. lbs. lighter (3lbs. to 5lbs.). Clean well and use Loctite if the lighter torque makes you feel better.
Back when I had my Pro Gas car (Anglia), the third members I assembled for that....the pinion nut only had 10ft.lbs. and Loctite. 12 years of weekly drag racing (9.90's at around 134mph) and never tore up a rear end.
