Sorry, can't figure out how to delete this thread with misspelling in heading.
What is the best cleaner you have found for the white walls on your Studebaker's tirea?
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly ownedTags: None
What is the best cleaner you have found for the white walls on your Studebaker's tires?
I haven't tried to clean white walls in years, I think as a kid I used SOS pads. What's the thing to use now?Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
If memory serves me right, the Diamond Brands vintage tire folks have some strong opinions and information on this subject. Check their website. I hate cleaning white walls, and even took them off my retro-look motorcycle.John Clary
I'll probably get laughed at but I use a sray bottle of laundry stain remover called "Shout". Somehow I tried it many years ago and found that by spraying my white walls or white letter tires with it and letting them sit for a minute or two it disolved all of the dirt alnd left the whitewalls bright white. It also works well on removing grease from engines or parts and occasionally I use it on my hands in a pinch.
RandyRandy Ridenour
Frostburg,MD
1964 GT Hawk
The Westley's works great but, it is highly alkaline and will deteriorate the rubber and affect any painted surface. I love it for some purposes but NOT FOR TIRES!
Soap, water and a Scothbrite pad.Brad Johnson,
'56 Sky Hawk in process
Originally posted by 52hawk View PostI 2nd the Westleys-available at some flaps or walmart. if you get Westleys on your paint,rinse it off quickly."Growing old is mandatory, but growing up is optional." author unknown
Do NOT use anything with bleach in it (Westley's). It will dry out the rubber in the white walls and they will eventually start cracking. I have been using the advice from Diamondback tires, and have found that a fine or medium sanding sponge works great. If they are very dirty or greasy, try an SOS pad, but rinse thoroughly and don't use it very often. I have been driving with wide whites for 9 years now and this is what I have learned.
PatPat Dilling
Olivehurst, CA
I was told that the Mr. Clean "Magic Erasure" was great for my white walls on Oscar. I used them one time and now they are all spyder cracked and dried out. The pads worked great for removing the scuffs that I got on the whitewall, but now they are 6 months old and look terrible.
BE CAREFUL...mild soap and water with a pot scrubbber pad or scotchbrite works great.
