The 54 commander is positive ground, can a negative ground electric fuel pump be used? Ken, Deltaville, Va
Electric Fuel pump
Tags: None
Yep...just swap the wires at the pump.
BUT...remember, unless you buy a "really" low output pump, you'll also need a regulator to drop the pressure.
I've got a Carter 7psi pump on my, 6 volt, positive ground, 54 wagon. All set up to be correctly redone when the 299 goes in.
So far as it stands this combination has about 2500 miles on it with no problem. Currently adjusted to 3 psi for the flat head 170 in it now.
Originally posted by Mike Van Veghten View PostYep...just swap the wires at the pump.
There are some polarity-sensitive pumps out there. The "Facit" brand comes to mind. They look like a little metal cube with a hose barb on two opposing faces, and a large power transistor on one of the other faces. Very similar pumps were used in many Mazda rotary-engine cars.
Any device with solid-state components, e.g. transistors, in it will be polarity-sensitive. And rotary pumps may run in reverse if hooked up with incorrect polarity.
There's a simple solution: simply mount the fuel pump on a sheet of thick rubber, and bolt the rubber sheet to the car frame, ensuring that the screws holding the pump to the rubber cannot make contact with the frame. With a short length of good-quality neoprene hose on each nipple, the pump is electrically isolated, and noise transmission to the car interior is greatly diminished, too.Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by RadioRoy View PostGood information Gordr.
You can also secure the pump to the rubber to the frame with plastic tie wraps.
Do they make electronic pumps in 6 volt?
