I changed the entire rear end in my Avanti from a 3.54 to a 3.07. Today I finally got a chance to test it. The car started moving, but the speedometer needle didn't. I had bought a new pinion with the correct number of teeth for the 3.07 and my son installed it while he was doing some other under car work. Simple enough I said to myself, he didn't get it in far enough or forgot to tighten the clamp that holds it in the transmission. So, i crawled under the car and took the cable loose. Had the wife watch the speedometer while I turned the pinion. Speedometer reacted OK so I re-installed the cable and made sure it was right. Got in the car, it moved, but again the speedometer didn't. Crawled under the car, removed the cable from the transmission and pulled the pinion out and compared it with the one from the 3.54. Exact same length, design and diameter, just different number of teeth. So, I decided maybe it was pushed too far on to the bottom of the speedometer cable and I put it on, but left a gap between the gear and the end of the speedometer shaft. Had the wife verify speedometer needle movement- OK. Re-installed it, car moved, no speedometer movement.
So, what now? The shop manuals don't say anything about installing the pinion. I really don't want to drive it to South Bend with an inoperative speedometer.
