How would you get around the problem of having an electronic speedo sender unit, from a non-stude tranny, running the original cable driven speedometer?
Tricky Problem
Tags: None
Originally posted by Aussie Hawk View PostHow would you get around the problem of having an electronic speedo sender unit, from a non-stude tranny, running the original cable driven speedometer?
If you need the electronic signal for a computer control and the cable drive then it can get tricky but is do-able with the correct adapter.
BobLast edited by sweetolbob; 07-20-2012, 03:50 PM.
